Wall Connection: Interior / Exterior
RobUSMC
Not sure if im missing something simple here. As you can see in the attached pic, I have an interior wall intersection into an exterior wall. I need to have the framing continue seamlessly from the exterior to the interior. I have object snap on, I have tried to use the connect wall tool, the build wall /  fix wall connection tool and tried to rebuild walls with no movement / alignment.
Thank you for input
Rob
If you are using grid snaps, set them to like 1/4". That I find works good b/c since a typ. wall is 3.5", it will snap with better alignment. Any smaller
will tax you computer(extra decimals) and Chief, and some big jobs could overload the system.
