Missing Half the Jamb in Doorway in Double Wall
Adam_Gibson
The title says is all. What's up with that? I don't remember ever having this issue. I placed the doorway in the wall to the right. It created the matching opening just fine, but only put jamb on the right side.
I have seen this,  I ignored it,  should not be this way,  it would be great if you would send it in as a bug,
Almost. Nice try. Would this qualify as a bug?
Yes, and while they're at it they should give us control of the unsightly dark lines at the edge of the wall.  I've never been able to figure out how to adjust the line weight and the fact that it extends to the outermost wall surfaces.
OK, so the "Framed Opening" line is controlled by the setting for "Walls-Normal" (which is typically the "Main Layer Only").  But this "Framed Opening" doesn't stop at the "Main Layer" - it continues out to the outermost wall surface.
CA, please fix this - at your leasure...... :rolleyes: :rolleyes:
