BryceEngstrom Posted September 10, 2015 Share Posted September 10, 2015 Are skylights really this bad OOB, or am I just missing something? I have played around with the various settings and trying to custom adjust the ceiling opening but it's not even close to being clean. Skylights.plan Link to comment Share on other sites More sharing options...
Kbird1 Posted September 10, 2015 Share Posted September 10, 2015 There was a post on Skylights a while back where Scott and perhaps Bill Emery? played around with the skylight holes etc , not sure they got it perfect though. edit: found it..... it was Larry Sweeny , Scott did a vid. https://chieftalk.chiefarchitect.com/index.php?/topic/2183-skylight-problem/?hl=skylight M. Link to comment Share on other sites More sharing options...
jcaffee Posted September 10, 2015 Share Posted September 10, 2015 What are you trying to achieve? jon Link to comment Share on other sites More sharing options...
BryceEngstrom Posted September 10, 2015 Author Share Posted September 10, 2015 What are you trying to achieve? jon Well, an automatically generated hole in my ceiling plane that doesn't have a huge gap between it and the shaft would be a good start. Look at the lines being cut in the ceiling plane at the bottom of the section view. WTH? Link to comment Share on other sites More sharing options...
BryceEngstrom Posted September 10, 2015 Author Share Posted September 10, 2015 There was a post on Skylights a while back where Scott and perhaps Bill Emery? played around with the skylight holes etc , not sure they got it perfect though. edit: found it..... it was Larry Sweeny , Scott did a vid. https://chieftalk.chiefarchitect.com/index.php?/topic/2183-skylight-problem/?hl=skylight M. Thanks for that. Funny, reducing the framing dimension of the ceiling plane was one of the things I did try and got those "shards" Scott talks about in the early part of that video. Add this to the seemingly endless secret handshakes people complain about with Chief. I concur with Scott, this really needs to be fixed. Link to comment Share on other sites More sharing options...
jcaffee Posted September 11, 2015 Share Posted September 11, 2015 Would you really build square>plumb>square? My lack of field experience, I guess. I've always designed it as square, or plumb, or plumb/square, but never anything other than a straight walled shaft. And yes, skylights/roof attachments needs fixed in CA. I was just wondering if I might help with a "secret handshake" jon Link to comment Share on other sites More sharing options...
BryceEngstrom Posted September 11, 2015 Author Share Posted September 11, 2015 Just the fact that they don't cut a clean hole is one thing. HOW the shaft is cut is a whole other issue and I agree the options don't really allow easy creation of a shaft the way they are typically built. Will send in a bug report just to add to the list I suppose. Link to comment Share on other sites More sharing options...
Bill_Emery Posted September 11, 2015 Share Posted September 11, 2015 Chief's tools with regard to Skylights, are fairly basic, and I can understand the frustration. But they do good job of representing the ugly, useless way that they are built in my region. That said, forget about using the Chief shaft, and use walls, and ceiling planes to define creative light shafts, and wells; instead of using a tract home tool. The screen shot shows a trussed roof with girders to form the well. Link to comment Share on other sites More sharing options...
