WendyatArtform Posted September 9, 2015 Share Posted September 9, 2015 Here's a little bad boy condition that I had to fix, so I taped it. This touches on the following topics: messy outside wall connection at dormer cheeks. In this case it's related to attic walls and the roof eave being higher than the ceiling. misbehaving frieze at roofs with jogs. getting corner boards and rafter tails to look the way you want at dormer outside corners. Even though this is not technically a "dormer", it's definitely dormer-ish. So techniques from here can be applied directly to dormers. it's the three videos titled "Roof Schmutz" in the Dormer library folder - http://www.screencast.com/t/FotMcxvnpAI Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted September 9, 2015 Share Posted September 9, 2015 Nice to watch you work. Thanks! Link to comment Share on other sites More sharing options...
HumbleChief Posted September 9, 2015 Share Posted September 9, 2015 GREAT video. Not sure who to thank that I live in CA and don't have to deal with frieze and corner boards! Link to comment Share on other sites More sharing options...
Kbird1 Posted September 10, 2015 Share Posted September 10, 2015 Thanks Wendy , good vids again. MUCH appreciated. Not sure you saw it yest. but there is a post on that arrow you are using and how it has a Bug in X7and it not resizing itself properly on Zooming , I had stopped using it too , but Kirk confirmed it is a "known issue" here: https://chieftalk.chiefarchitect.com/index.php?/topic/6437-temporary-dimension-extension-arrows/#entry58140 Link to comment Share on other sites More sharing options...
