KittleDesign Posted August 15, 2015 Share Posted August 15, 2015 I have a client that wants to see a 3D rendering of this timber frame structure. I can do the straight posts and beams, no problem, but I don't know how to generate the curved beams. What shapes/solids do I use, or should I draw a flat 2D polyline and then extrude it and give it depth? Most of my clients don't want me to put the extra time (money) into the fancy scroll work on the ends of the beams and such but this client wants to see all of it in 3D. Please just get me on the right track and, hopefully, I can figure it out from there. Thanks, Jess Kittle Kittle Custom Home Design Chief Architect X6 Link to comment Share on other sites More sharing options...
Kbird1 Posted August 15, 2015 Share Posted August 15, 2015 there is a new Timber Frame House in the CA Samples Gallery you could download to look at for ideas here http://www.chiefarchitect.com/products/samples.html and I thought I had seen a tutorial on Timber Frame trusses in the KnowledgeBase (KB) too did you look? If it's a Motorcoach (RV?) Pavilion are you sure that it is high enough > 7'6" is only 6" higher than a standard garage door. Link to comment Share on other sites More sharing options...
chief58 Posted August 15, 2015 Share Posted August 15, 2015 I did one out of poly line solids then changed the material to wood Link to comment Share on other sites More sharing options...
KittleDesign Posted August 16, 2015 Author Share Posted August 16, 2015 Kbird1, it's an outdoor kitchen and living space, it goes next to their motorcoach, not over the top of it. No, I did not check either of those places, thanks for the suggestions, I will check them out. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 16, 2015 Share Posted August 16, 2015 makes sense as an outdoor entertaining Area, from the name I thought it was a shelter for the MotorCoach. M. Link to comment Share on other sites More sharing options...
KittleDesign Posted August 17, 2015 Author Share Posted August 17, 2015 I appreciate the help, here is a view of the structure, so far. I still have the kitchen and the fireplace to put in but I got the timber frame stuff worked out, thanks again. Link to comment Share on other sites More sharing options...
