window not framing through
Dennis_Gavin
I deleted the window and copied one of the basement windows into that place and resized it and it framed through.
When I tried to move the wall for the sump closet closer in I lost the frame through.  Not sure why.  I guess there is
a minimum distance you have to be from a corner or wall angle to have the frame through work?  I know I can put a pass
through in but wanted to do it automatically.
Hey Dennis,
I was having the same problem this morning on a plan.
My issue was with a triple window. It didn't like it if it wasnt blocked as one unit. Then it worked.
I did notice in your image that the furring wall to the north is a bit  away from the foundation wall. The wall on the east is not.
Try a 1 inch air gap in the wall type, also make sure its a furred wall.  this way it bumps to the air gap when you place it.
HTH,
