Larry_Sweeney Posted July 2, 2015 Share Posted July 2, 2015 I'm using a railing wall on a stairs so I can have a bottom rail. I have a baluster that is 3/4"x2" that I want to use. When I install it in the railing wall it is turned the wrong way with the 2" dimension running across (perpendicular) the rail rather than with (parallel) the rail. Is there a way to rotate the balusters or am I going about building the stair rail entirely wrong? Link to comment Share on other sites More sharing options...
DRAWZILLA Posted July 2, 2015 Share Posted July 2, 2015 You may have to create a custom panel for that or a symbol. Link to comment Share on other sites More sharing options...
Bill_Emery Posted July 2, 2015 Share Posted July 2, 2015 Save the baluster to the user library. Open the symbol and rotate it 90 degrees. Then open the stairs and change to the new baluster. Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted July 2, 2015 Author Share Posted July 2, 2015 Bill..............Yes, that's what I ended up doing. It would be nice if in the railing dbx. we were allowed measurements in both directions. CA must think people only us square balusters. Have a great day. Link to comment Share on other sites More sharing options...
