DianeP Posted June 9, 2015 Share Posted June 9, 2015 Is there a way to show the edge of the deck and the railing in plan view? I can only see the railing and want to keep it since it has my column positions. is there a setting I need to change so that I can see the deck edge? Thanks a bunch! Link to comment Share on other sites More sharing options...
HumbleChief Posted June 9, 2015 Share Posted June 9, 2015 Build deck framing, turn on the deck framing layer? Link to comment Share on other sites More sharing options...
DianeP Posted June 9, 2015 Author Share Posted June 9, 2015 Yes, this works. I would like to see the edge of the deck or balcony without all the framing members. Any ideas? Link to comment Share on other sites More sharing options...
Solution HumbleChief Posted June 9, 2015 Solution Share Posted June 9, 2015 You could put the framing member that is the edge of the deck on a separate layer, turn it on, the rest of the deck framing layer off? Link to comment Share on other sites More sharing options...
DianeP Posted June 9, 2015 Author Share Posted June 9, 2015 Good fix. Thanks! Link to comment Share on other sites More sharing options...
