Centering Walls On Footings
Paramount
Go to solution Solved by Paramount,
  • Solution
Got is thanks! My first model and I think I confused myself by trying to create my foundation using the wall specs in the first floor that works differently than the foundation floor using the floor tool "build foundation"....I was not noticing my outer clading in flush to the outer footing where it should be. If I wanted to change the layers of the wall to add say a brick layer I guess I add that layer to my wall.
I take it is best to build foundations on the foundation floor and not try and build them on the first floor using wall specs?
