builtright3 Posted May 13, 2015 Share Posted May 13, 2015 Please help with the attached section view. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted May 13, 2015 Share Posted May 13, 2015 Make your sub-fascia to 1/16" thick and change your blocking to vertical in the framing DBX and don't forget to re-build the framing.. The sub-fascia controls the depth of the eaves so you could get a 2x4 eave on a 2x10 rafter if you already didn't know. Link to comment Share on other sites More sharing options...
builtright3 Posted May 14, 2015 Author Share Posted May 14, 2015 I would like the block on top of the wall as the picture is so the stucco can continue to the roof sheeting but this is close enough. Might be asking for to much. Thank You Link to comment Share on other sites More sharing options...
DRAWZILLA Posted May 14, 2015 Share Posted May 14, 2015 You can move it in place after. Link to comment Share on other sites More sharing options...
builtright3 Posted May 14, 2015 Author Share Posted May 14, 2015 Ya I figured out that I can move the block after I asked you. The section is looking pretty good then I noticed the patio double slab and the way it penetrates the footing. Any thoughts their? Thanks for your time Perry Link to comment Share on other sites More sharing options...
builtright3 Posted May 14, 2015 Author Share Posted May 14, 2015 Got it all figured!!! Looks clean now Thank You!!!! :) Link to comment Share on other sites More sharing options...
