builtright3
Fascia, Sub Fascia And Blocking
Make your sub-fascia to 1/16" thick and change your blocking to vertical in the framing DBX and don't forget to re-build the framing.. The sub-fascia controls the depth of the eaves so you could get a 2x4 eave on a 2x10 rafter if you already didn't know.
I would like the block on top of the wall as the picture is so the stucco can continue to the roof sheeting but this is close enough. Might be asking for to much.
Thank You
You can move it in place after.
Ya I figured out that I can move the block after I asked you.
The section is looking pretty good then I noticed the patio double slab and the way it penetrates the footing. Any thoughts their?
Thanks for your time Perry
    27450
    Elliot
    Elliot
