mslewis620 Posted May 9, 2015 Share Posted May 9, 2015 For some reason auto ext dim has started acting up. Checked the usual suspects and for the life of me can't find the source of the problem. When I use auto exterior only part of the floor plan is dimensioned. I've tried deleting all dimensions and starting over but nothing works. X6 user Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 9, 2015 Share Posted May 9, 2015 Sounds like maybe a bad wall connection. Perhaps you should attach the plan. Link to comment Share on other sites More sharing options...
Kiwideziner Posted May 11, 2015 Share Posted May 11, 2015 try putting a room pline around the building as the probable cause is as Michael said. this will prove it. Link to comment Share on other sites More sharing options...
