Doug_Park Posted May 7, 2015 Share Posted May 7, 2015 On 5/7/2015 at 12:09 AM, glennw said: Dan, Or...we just need to be able to drag the drawing sheet around in layout - same as we can do in plan view. That way the printing page size is set. The Export emf relies on drawing a marquee which could be any size - not necessarily relating to the printing page size. Go to page 0 and you can do this. Link to comment Share on other sites More sharing options...
glennw Posted May 7, 2015 Share Posted May 7, 2015 Doug, But what happens if I want to pint a section of a page other than page 0? It would make it a lot easier if you could move the drawing sheet around on any layout page. Link to comment Share on other sites More sharing options...
brushpark Posted May 9, 2015 Author Share Posted May 9, 2015 The elevation views will be put into a drop box for the installer to grab and print off on 8 1/2 x 11" to scale since this is a common printer size. Each sheet could be printed and carried into the room which the tile is being installed. I just wished I would have know before I setup the drawing sheets. I also believed there would be a way to print an area of the drawing like I have in AutoCAD. Chief needs to work on this printing issue!! Link to comment Share on other sites More sharing options...
brushpark Posted May 9, 2015 Author Share Posted May 9, 2015 OH, and thank you MarkMc for your kind offer! Link to comment Share on other sites More sharing options...
