Wall Material Does Not Update
ReddJammer
Also - Alt-Q, and turn off "Auto Rebuild Attic Walls" while you're working.  That will prevent attic walls being build from the first floor before you've created the second floor.
To see if any there already - Go to an All Off layerset, temporarily turn on Walls, Attic and see if you spot any bad boys.  Or delete all attic walls, easy enough to let it rebuild (recheck box, do any 3D view)
And/or - make sure wall on first floor below is NOT set to "balloon" on the structure tab.
