ChiefKenE Posted Friday at 11:49 PM Share Posted Friday at 11:49 PM Sometimes when I try to generate a Cross Section/Elevation from a floor plan the Orthographic camera does not generate the section/elevation. Has anyone else experienced this or can offer any solutions? Thanks, Ken Link to comment Share on other sites More sharing options...
PitMan71 Posted Saturday at 01:53 PM Share Posted Saturday at 01:53 PM This sounds strange... i have never experienced that before. What version of CA are you using? Is it a particular plan that is doing it? 14 hours ago, ChiefKenE said: Orthographic camera does not generate the section/elevation I would also want to know what specifically do you mean by this? is nothing happening at all or is the camera view blank? Posting your plan might help..... You will need to zip it up. Link to comment Share on other sites More sharing options...
DBCooper Posted 23 hours ago Share Posted 23 hours ago Check to see if your plan is really far away from the origin (0,0). This is known to cause all kinds of strange problems. If so, then you can use "edit area' to move it back close to the origin. See if you have any "shark fins" or other objects that are shooting out into outer space when you create a 3d perspective view (not an overview). Sometimes when you have an object that shoots out, the camera view will be zoomed so far out, you can't actually see anything. When this happens, you need to find the object and remove it or figure out what is shooting out and fix it. Facia boards and moldings can sometimes do this when they have bad connections. If it's not one of those, you might need to post your plan (or contact tech support). Link to comment Share on other sites More sharing options...
