floor heights have changed
Quote
All my floor heights have changed on a three story house from basement to third floor and missing elevations
You didn't give us much information so it is going to be hard to give you any help.  When did your floor heights change and what did you do right before then?  When you say you are missing elevations, where are you missing them?  Does your plan have different floor heights on the same floor level or are they all the same?  You might need to post your plan with more details about what you are having problems with.
Since you are a first time poster, I am going to assume you are new to Chief.  This tech info might help:
https://www.chiefarchitect.com/support/article/KB-00579/controlling-wall-floor-and-ceiling-heights.html
https://www.chiefarchitect.com/support/article/KB-00938/how-the-height-of-floors-relate-to-the-height-of-the-terrain.html
https://www.chiefarchitect.com/support/article/KB-02989/message-ceiling-values-may-not-be-changed-as-the-floor-above-this-room-has-varying-heights.html
https://www.chiefarchitect.com/support/article/KB-01855/modifying-garage-floor-and-stem-wall-heights.html
