TheBandedBee Posted March 19 Share Posted March 19 Hi everyone, I am looking for an option to fade out a certain part of my elevation. I would like 2/3 on the left hand side to be faded out whilst the 1/3 on the right hand side stays clear and crisp. I played around with the depth cue function, but this only fades out from the front of the elevation towards the back of the building. I want to fade out side ways if that is possible to showcase an extension to the building. Thanks. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 19 Share Posted March 19 (edited) Have you tried a semi-transparent mask? Essentially a Polyline with a solid white fill (about 35% transparency) in front of that portion of the elevation BTW, it's best to use the Q&A Forum for questions. Tips & Techniques are where you post how you do something that other users can benefit by. Edited March 19 by Joe_Carrick 1 1 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 19 Share Posted March 19 I would also like to be able to fade out from back to front. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 19 Share Posted March 19 19 minutes ago, Renerabbitt said: The depth cue was never built properly, its just a linear approach, it doesnt properly map depths like a true depth cue would That's not the OP's problem. He wanted to block areas of the elevation to indicate existing vs new. My post above provides that funcionality. Link to comment Share on other sites More sharing options...
TheBandedBee Posted March 19 Author Share Posted March 19 Thanks guys, much appreciated. I will give that a try Joe. Link to comment Share on other sites More sharing options...
