Wall type - Log walls
AbeLopez
I just use a single grout layer (7" thick) - not framing - wall type and then stack logs as follows.
  • (9" diameter cylinders -symbols)
  • half logs (top and bottom)
  • generally stack the logs at 1" less than the diameter.
This allows me to insert doors and windows in the wall - but the logs have to be adjusted lengthwise.
It's best to place the doors and windows before stacking logs.
You can get close to automatic with a very custom set of textures stacked up in your wall type. incrementally shapes the logs
image.thumb.png.9a242d139e53263406bc8cec09664615.pngimage.thumb.png.f1b3e258cfbec94828daee3220d4b35d.png
You would add quoins that are custom to recreate the log ends at the corners which I do not have shown
Edited by Renerabbitt
There are also log sybols in the library
  • Core>Exteriors>Logs
Basically I just prefer to do log homes the same way they are built.  That is the only - or at least the easiest - way to get a complete quantity take-off.
Edited by Joe_Carrick
