heedaf Posted yesterday at 02:51 AM Share Posted yesterday at 02:51 AM I got GPS data from my lot I want to build on. Is there a way to scale it? Lot is 100' wide but the gps coordinates come in at 157' wide. Not sure why but all I need is the slope of the lot. Link to comment Share on other sites More sharing options...
Rich_Winsor Posted yesterday at 10:42 AM Share Posted yesterday at 10:42 AM 100/157 = 0.6369426751592357 Multiply your gps coordinates by this number and they will be 100' wide. Link to comment Share on other sites More sharing options...
SHCanada2 Posted yesterday at 04:39 PM Share Posted yesterday at 04:39 PM If you have multiple points You probably want to take a subset that fit within 100ft. You could scale the elevation data if you are only given two points for 157ft. What exactly do you have? A question would be, did you get wrong GPS data for 100ft or did you get bigger GPS data that represents 157ft. And did you get more than 4 points Link to comment Share on other sites More sharing options...
heedaf Posted yesterday at 05:50 PM Author Share Posted yesterday at 05:50 PM 1 hour ago, SHCanada2 said: If you have multiple points You probably want to take a subset that fit within 100ft. You could scale the elevation data if you are only given two points for 157ft. What exactly do you have? A question would be, did you get wrong GPS data for 100ft or did you get bigger GPS data that represents 157ft. And did you get more than 4 points Just got a gps app on the phone and walked the lot. Strange that it would be that far off. Around 400 points with the lot. I guess I need to go measure the lot to make sure it is 100' wide. Link to comment Share on other sites More sharing options...
heedaf Posted yesterday at 05:50 PM Author Share Posted yesterday at 05:50 PM 7 hours ago, Rich_Winsor said: 100/157 = 0.6369426751592357 Multiply your gps coordinates by this number and they will be 100' wide. Is there a way to do this via software or do I need to manually do it? Link to comment Share on other sites More sharing options...
JiAngelo Posted 23 hours ago Share Posted 23 hours ago Pretty sure this isn't a scale problem. Phone gps apps are only accurate to +/-16ft radius. That's +/-16ft at each point you measure. The error distance grows if obstructions exist - trees, clouds, adjacent structures. The quality of the phone's internals affect this as well. If you stood on two points that you know are 100' apart and shot 157', find a third point that is a known set distance from the first two points. Best if 【1-3】does not equal 【2-3】 . Go out there with a 100ft tape and pick one. Calculate (Actual Distance) / (Recorded distance) values for points【1-2】, 【1-3】 and 【2-3】, if they dont all equal 100/157 then you can't scale. I would wager if you shot 【1-2】 again you'd get a different number. 1 Link to comment Share on other sites More sharing options...
SHCanada2 Posted 23 hours ago Share Posted 23 hours ago (edited) 2 hours ago, heedaf said: Just got a gps app on the phone and walked the lot. Strange that it would be that far off. Around 400 points with the lot. I guess I need to go measure the lot to make sure it is 100' wide. GPS do not give accurate elevation data(which is needed for slope), like not even close, I think mine might be accurate to 50ft vertically(absolute) and who knows on a delta between two points. I tried it a few years back and it was all over the place for the delta. Your better bet is a transit or laser at dusk ....once you determine where the property corners are at physically. or go old schoold with a water level I also have a zip level for when you do not have line of sight. ..or just ask the customer for a survey...or get one done. The cheapest way, laser level if you know where the property corners are Edited 22 hours ago by SHCanada2 Link to comment Share on other sites More sharing options...
