Easements
builtright3
Hey Guy's,
I was trying to figure out the best way I can verify utility easements for the properties that I’m drawing plans for and building on.
I would usually tell the owners to get me the tile /deed for the property and also go to the county clerk’s office but I’m told that is not always accurate.
I’m also being told that the best way is to get a preliminary report from a title company but that takes a little time and is very expensive.
I’m working in California. Does anyone have any suggestions for me?
3 hours ago, builtright3 said:
Hey Guy's,
Most counties have a GIS and for each property on the GIS their is typically a link buried somewhere to the assessors map of record
I order a new survey for every project (where required), so I leave it to the surveyor to figure out. It limits my liability. I also get a DWG of the survey to create my topo model from.
Edited by RobDesLLC
Yes, I use those maps all the time.
What I have learned is that as architects, designers and builders we need to show absolute proof that we are not building over an easement. With these new ADU guidelines we can build up to 4 feet from the property line in the back and sides of the property but what is being over looked is that Edison easements are typically in the back of the property and depending on where the pole is located the setback is usually 4,5 or 6 feet from the back property line.
We are opening ourselves up for future lawsuits if we don’t have documentation of where these easements are.
Yesterday I contacted a Title company that I will be using on all future jobs where this could possibly be an issue. From what I have learned that getting a PRELIMINARY REPORT from a title company is your most accurate way of getting the information needed.
I have a current property now that the city will allow me to build 4’ feet to the property line but Edison has a 6 foot easement. The cities are not regulating this, it is up to the homeowner, builder and architect. This could be a big problem for me down the road if I were to build over their easement.
@builtright3 why would any jurisdiction allow you to build over an easement? I don't see the issue at all! Unless someone decides to build without permits. The moment you submit your plans to any jurisdiction, it undergoes the review process by all pertinent departments, if you are showing your structure over an easement, you will get a correction stating that there's an easement there!
I kept from posting because the op was of no value.
Property research should be part of all projects and part of your contract, so no mistakes are made.
Either you do the legwork or have a "gopher" to run your errands.
If the jurisdiction has GIS they likely also have a Surveyor's GIS which is different and you can search their maps there.
If the jurisdiction has GIS you can easily find the APN, with it you can find where to download the parcel map, with that you can read it and find the book and page of the survey map, with that you find the surveyor's GIS and go through all the maps if more than one is available and read the maps to see if an easement exists! If all that fails and you still want to double check, send the "gopher" to the county recorder's office and request the record of survey for your area as well as any recorded easements. If you have been in this business long enough you may also want to ask if any easements have been "quit deed" or are discontinued.
Hope this helps.
Edited by jorgearaya
Yes you would think that the city would regulate this before you get a permit but the simple fact is that some cities do not and do not take liability.
The reason all of this came up with me is that I was told by an Edison planner that they have had over 100 lawsuits in the La Area just over the last year.
I’m not typically asked to show the easement information on my plan but now they are asking.
I have not had to deal with this in my 34 years of business because I have mainly drawn and built room additions. Now that I have been building ADU’s a lot has changed for me.
I’m putting this out there to possibly help others that are in my situation. Not all contractors that draw their own plans are aware.
I’m not always required to have a surveyor because the boundaries are pretty clear on most lots but sometimes on larger projects or lots were the boundaries aren’t clear.
Thanks for your input!
They don't
You have a setback requirement, in this case 4'
you have an easement, in this case 6'
you could build up to the 4' setback, if their were no easement, but there is one, so you cannot encroach on that easement.
All the planning dept will do will check to see if your setbacks match criteria, and are unaware of an easement on your particular property...hence the lawsuits
40 minutes ago, Renerabbitt said:
They don't
Thank you, Rene,
I'm not always good at articulating what I’m trying to say.
