Room Finish Schedule Wall Material
ACADuser
This can happen when there are multiple wall types surrounding the room, including pony walls.
In your case, it's the wall with the lable "STUCCO THIS SIDE".  Check that wall definition - maybe reverse the wall layers.
Personally I don't use that column simply because of this.  Instead I use "Wall Schedules" which can have macros to display all the wall layers.
Edited by Joe_Carrick
Im curious what tech support says. It's irritating to me to have to throw the baby out with the bathwater. in this case people will avoid using an entire column because it can't be relied on to provide the information needed. If there is a nuance surrounding a certain room feature, I'm am totally okay with it so long as we have the ability to override it.
Fix it and be done instead on taking what seems like hours to track something down.
The problem's that there's no column for individual walls of a room.  If there was at least 4:
  • North or 1
  • East or 2
  • South or 3
  • West or 4
It would be possible to have a fully functional Finish Schedule.
You can have custom fields for those and manually assign the values for each room.  It's a little more work but the Schedule would be more interesting.
