ACADuser Posted Sunday at 12:46 AM Share Posted Sunday at 12:46 AM I would like the wall material to show only the material inside that room. Can that be done? The exterior walls display stucco which I do not want to see in the schedule. Link to comment Share on other sites More sharing options...
PitMan71 Posted Sunday at 01:32 PM Share Posted Sunday at 01:32 PM I see this when I have a dormer in a room. For some reason it shows the interior walls and exterior wall finish in the schedule. Is that what you mean? Link to comment Share on other sites More sharing options...
ACADuser Posted Sunday at 01:43 PM Author Share Posted Sunday at 01:43 PM (edited) Not all rooms do this? [Edit] I just sent it to tech support. Edited Sunday at 01:58 PM by ACADuser Link to comment Share on other sites More sharing options...
Joe_Carrick Posted Sunday at 02:21 PM Share Posted Sunday at 02:21 PM (edited) This can happen when there are multiple wall types surrounding the room, including pony walls. In your case, it's the wall with the lable "STUCCO THIS SIDE". Check that wall definition - maybe reverse the wall layers. Personally I don't use that column simply because of this. Instead I use "Wall Schedules" which can have macros to display all the wall layers. Edited Sunday at 02:35 PM by Joe_Carrick Link to comment Share on other sites More sharing options...
ACADuser Posted Sunday at 03:14 PM Author Share Posted Sunday at 03:14 PM Thanks Joe, I've messed with the 3 wall intersection with no luck. You solution will solve my problem. Link to comment Share on other sites More sharing options...
ACADuser Posted Sunday at 03:32 PM Author Share Posted Sunday at 03:32 PM Joe, How do you deal with a wall type that has 3.5" sound insulation in it? The project I'm doing, small laser studio, has mostly insulated partitions. So I have a wall type for that. Link to comment Share on other sites More sharing options...
PitMan71 Posted Sunday at 05:33 PM Share Posted Sunday at 05:33 PM Im curious what tech support says. It's irritating to me to have to throw the baby out with the bathwater. in this case people will avoid using an entire column because it can't be relied on to provide the information needed. If there is a nuance surrounding a certain room feature, I'm am totally okay with it so long as we have the ability to override it. Fix it and be done instead on taking what seems like hours to track something down. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted Sunday at 10:12 PM Share Posted Sunday at 10:12 PM (edited) 4 hours ago, PitMan71 said: It's irritating to me to have to throw the baby out with the bathwater. in this case people will avoid using an entire column because it can't be relied on to provide the information needed. The problem's that there's no column for individual walls of a room. If there was at least 4: North or 1 East or 2 South or 3 West or 4 It would be possible to have a fully functional Finish Schedule. You can have custom fields for those and manually assign the values for each room. It's a little more work but the Schedule would be more interesting. Edited Sunday at 10:13 PM by Joe_Carrick 1 Link to comment Share on other sites More sharing options...
