CA_Russell Posted February 1 Share Posted February 1 All, Curious are the "Default Settings" project based or application based? I'm wondering if I modify them, and make a mistake... what is my recovery option. Also, if it's per Project, then I could just delete the Project from the working folder. Sincerely, Ryan Russell Link to comment Share on other sites More sharing options...
Chrisb222 Posted February 1 Share Posted February 1 Just now, CA_Russell said: Curious are the "Default Settings" project based or application based? Defaults = project based Preferences = application based 1 Link to comment Share on other sites More sharing options...
DBCooper Posted February 1 Share Posted February 1 Also, if you want to change your "defaults" and then make it so that new plans will start with these defaults, you will need to setup your plan template to have them. This tech article might help: https://www.chiefarchitect.com/support/article/KB-00463/creating-and-using-plan-templates.html 1 Link to comment Share on other sites More sharing options...
