builtright3 Posted 8 hours ago Share Posted 8 hours ago I would like to change the existing roof of this house to a higher pitch and make it a gable without it affecting the lattice cover roof plane that I created. What would be the best way to do this? I would typically delete the main house roof plane and rebuild manually because I know the automatic roof plane would wipe out the old. Is there a way to protect the lattice cover and still use the automatic roof planes? Link to comment Share on other sites More sharing options...
Rookie65 Posted 7 hours ago Share Posted 7 hours ago I suppose you could copy it, might need to be item by item, then build the roof automatically, then "paste-hold position" for it to be put back where you want it? Link to comment Share on other sites More sharing options...
builtright3 Posted 7 hours ago Author Share Posted 7 hours ago 14 minutes ago, Rookie65 said: I suppose you could copy it, might need to be item by item, then build the roof automatically, then "paste-hold position" for it to be put back where you want it? I was thinking of that after I sent out the my question. I thought if I copy and past it to hold in place from my Asbuilt to my New Plan. Wasnt sure if that would work. Wont hurt to try it. Link to comment Share on other sites More sharing options...
builtright3 Posted 6 hours ago Author Share Posted 6 hours ago 1 hour ago, Rookie65 said: I suppose you could copy it, might need to be item by item, then build the roof automatically, then "paste-hold position" for it to be put back where you want it? Yes, it worked very easy to copy from one plan to the other. Thank you for your help. Link to comment Share on other sites More sharing options...
Mark3D Posted 4 hours ago Share Posted 4 hours ago I know you have it done but would these setting been of use Link to comment Share on other sites More sharing options...
builtright3 Posted 15 minutes ago Author Share Posted 15 minutes ago 4 hours ago, Mark3D said: I know you have it done but would these setting been of use Yes, that was what I was looking for. Not sure why I didnt see it when I was looking. Thank You Link to comment Share on other sites More sharing options...
