Secluding4344 Posted 3 hours ago Share Posted 3 hours ago (edited) New user of Chief Architect Premier X17 here. I have floor joists lapping over an interior bearing wall. The lap is being generated correctly by marking the wall as Bearing, but I’m trying to control which joist overlaps the other. Currently, the joists originating from the north side of the bearing wall lap to the left of the joists originating from the south side. I’d like to reverse this so the north-side joists lap to the right, meaning the south-side joists sit on the opposite side of the lap. Is there a setting or method in Chief to control the lap direction / joist precedence over a bearing wall, or is the lap order based on floor direction, room definition, or wall orientation? I’m not trying to change span direction only which side of the lap each joist set occupies if that makes sense. Thanks! Edited 3 hours ago by Secluding4344 Link to comment Share on other sites More sharing options...
