Secluding4344 Posted December 13, 2025 Share Posted December 13, 2025 (edited) New user of Chief Architect Premier X17 here. I have floor joists lapping over an interior bearing wall. The lap is being generated correctly by marking the wall as Bearing, but I’m trying to control which joist overlaps the other. Currently, the joists originating from the north side of the bearing wall lap to the left of the joists originating from the south side. I’d like to reverse this so the north-side joists lap to the right, meaning the south-side joists sit on the opposite side of the lap. Is there a setting or method in Chief to control the lap direction / joist precedence over a bearing wall, or is the lap order based on floor direction, room definition, or wall orientation? I’m not trying to change span direction only which side of the lap each joist set occupies if that makes sense. Thanks! Edited December 13, 2025 by Secluding4344 Link to comment Share on other sites More sharing options...
DBCooper Posted December 14, 2025 Share Posted December 14, 2025 I couldn't figure out a way to do it automatically. I tried playing around with the framing reference marker but it didn't seem to make a difference. Might be something you need to submit a feature request for. Link to comment Share on other sites More sharing options...
Mark3D Posted December 15, 2025 Share Posted December 15, 2025 Just select an move them maybe if understand your needs Link to comment Share on other sites More sharing options...
