susistrothman Posted 12 hours ago Share Posted 12 hours ago Hi all, Can anyone guide me on how to adjust my callout text size? When I am looking in the Working Plan View, the text is huge, but when I am in the Kitchens and Bath Plan View it's much smaller (screengrabs attached). I would like it to the be smaller size for all views. I have changed all the settings I can find that I think would even remotely do anything, but still haven't found the solution. Thanks in advance! Link to comment Share on other sites More sharing options...
Solution DBCooper Posted 11 hours ago Solution Share Posted 11 hours ago The text used by the callout is controlled by the text style used by the layer it is on. Go into the kitchen and bath view, select the camera. Look at the ALDO (active layer display options). It will tell you what layer the camera is using and what text style the layer is using. Do the same thing in the working plan view. If they are using different text styles, then the text will look different. If you want them to look the same, you will need to set them to use the same text style. It looks like you have turned off "automatic" for the callout size as well. You might want to turn that back on because it looks pretty silly with the callout text outside of the callout. Link to comment Share on other sites More sharing options...
susistrothman Posted 10 hours ago Author Share Posted 10 hours ago This was it! Thanks so much, DB Link to comment Share on other sites More sharing options...
