ESanchez7 Posted Tuesday at 05:40 PM Share Posted Tuesday at 05:40 PM I can't figure out why the 5 1/2" brick ledge won't display all the way around the foundation and then does some overlapping in other sections. Has anyone else run into something like this? Any help would be appreciated! 5 Link to comment Share on other sites More sharing options...
scottharris Posted Wednesday at 01:11 PM Share Posted Wednesday at 01:11 PM Maybe due to your wall type? Can you post your plan ? Link to comment Share on other sites More sharing options...
ESanchez7 Posted 7 hours ago Author Share Posted 7 hours ago The .plan file is too large to post here. Is there any other way to share it through here? Link to comment Share on other sites More sharing options...
DBCooper Posted 6 hours ago Share Posted 6 hours ago You can either make the plan smaller or post it somewhere on the cloud and put a link to it here. To make a plan smaller, you can try making a compressed archive (zip) of just the plan file (rather than the whole project which usually has stuff you don't need). Need to make sure you do this when the plan is not open in the program otherwise it might not work. If it is still too big, then make a copy of the plan and then delete the stuff that isn't part of the problem, especially things like fixtures, furniture, terrain, etc.. The "delete objects" tool is a good way of getting rid of things in a plan. Sometimes when you delete things the problem goes aways which can give you a clue about what is causing the problem. Link to comment Share on other sites More sharing options...
M-Reed Posted 4 hours ago Share Posted 4 hours ago (edited) I ran into that in X16 and Home Pro 2023 / 2024. Wall types did not matter other than they all used a brick facade. I ended up using CAD to fix for plan views. Interestingly enough, 3D views were fine. What is strange is every time I tried to rebuild walls using same settings, the errant lines ended up in differing places. Wrote it off as a bug and used best version and used CAD as indicated. Maxie Edited 4 hours ago by M-Reed Link to comment Share on other sites More sharing options...
ESanchez7 Posted 2 hours ago Author Share Posted 2 hours ago I tried to delete the majority of things, hope this works so you're able to see it. Thanks everyone for your help. 1701_Stonegate_Base_Plan C.plan.zip Link to comment Share on other sites More sharing options...
