MollyNDG Posted October 29, 2025 Share Posted October 29, 2025 Hi everyone, I’ve been running into a macro conflict issue with library objects and could use some advice. Here’s the situation: I create a macro in my plan and assign it to a custom field in a library object. Later, I tweak that macro in my plan. When I try to place the library object again, I get a message saying the macro conflicts with one already in the plan, which makes sense. So I delete the macro from the library object and place it again, but the conflict message still shows up. It seems like the macro is somehow still attached to the object. Is there a way to fully remove or reset the macro from the library object so I can avoid this conflict? I know I can just click “don’t show again,” but I’d rather fix it cleanly so the library object doesn’t override the macro in my plan. I have tried saving my plan, closing and reopening but get the same message when I place the library object (with no macro in it). Thanks in advance for any tips! Link to comment Share on other sites More sharing options...
Renerabbitt Posted 3 hours ago Share Posted 3 hours ago I just found this thread searching for something else. You would have to right click on your library object and update it from the TMM: Link to comment Share on other sites More sharing options...
MollyNDG Posted 1 hour ago Author Share Posted 1 hour ago @Renerabbitt I have never noticed that option in that drop down, I will give it a go. Thank you! Link to comment Share on other sites More sharing options...
