Lododesign Posted October 19, 2025 Share Posted October 19, 2025 Hi there from NZ. I am just in the starting out phase and wanted to know if there was a trial period where you can save your work. I wanted to design a plan as I work through the different elements of the design but it won't allow it. Alternatively, can you buy a 2nd had key for Premier? Many thanks. Lodo. Link to comment Share on other sites More sharing options...
SHCanada2 Posted October 19, 2025 Share Posted October 19, 2025 (edited) You cannot buy a used key. You can rent the software on a monthly basis if the trial limitations are ňot working for you. Although you might want to CA as I assume most here do not have a trial to verify the limitation with you Edited October 19, 2025 by SHCanada2 Link to comment Share on other sites More sharing options...
Lododesign Posted October 20, 2025 Author Share Posted October 20, 2025 Thanks for the reply. The month rental is very expensive $400+ That is a lot to try before you buy. Cheers Lodo Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 20, 2025 Share Posted October 20, 2025 I suggest you try the Home Designer version first. It's not as expensive as Premier but has most of the features you need. Then once you are satisfied with it you cn upgrade to Premier. Just understand that Premier is the Professional version which is for users that make a living with it. 1 1 Link to comment Share on other sites More sharing options...
