Newbie
Lododesign
Hi there from NZ.
I am just in the starting out phase and wanted to know if there was a trial period where you can save your work.
I wanted to design a plan as I work through the different elements of the design but it won't allow it.
Alternatively, can you buy a 2nd had key for Premier?
Many thanks.
Lodo.
You cannot buy a used key. You can rent the software on a monthly basis if the trial limitations are ňot working for you. Although you might want to CA as I assume most here do not have a trial to verify the limitation with you
Edited by SHCanada2
I suggest you try the Home Designer version first.  It's not as expensive as Premier but has most of the features you need.  Then once you are satisfied with it you cn upgrade to Premier.
Just understand that Premier is the Professional version which is for users that make a living with it.
  • Downvote 1
