mtldesigns Posted Sunday at 07:33 PM Share Posted Sunday at 07:33 PM Doing a wall section, and I noticed my top sill plate was 1/2" higher than what it's supposed to be. My ceiling heights are correct at 109 1/8". So I edited my Fascia Top Height to add that 1/2". That corrected situation, but I am wondering why that would make a difference in the 2 top sill plates? Link to comment Share on other sites More sharing options...
SHCanada2 Posted Sunday at 07:43 PM Share Posted Sunday at 07:43 PM (edited) Your bottom chord is lower than the top plate as you can see the truss being cut by the top plate. Maybe need to rebuild the framing to rebuild the truss. I see this frequently if I am fiddling with roof heights Edited Sunday at 07:45 PM by SHCanada2 1 Link to comment Share on other sites More sharing options...
mtldesigns Posted Sunday at 11:57 PM Author Share Posted Sunday at 11:57 PM 4 hours ago, SHCanada2 said: rebuild the framing to rebuild the truss I think you are right Jason. I probably should have rebuilt instead of raising the FTH. I did fiddled with this a bit. Link to comment Share on other sites More sharing options...
