DianeP Posted September 15, 2025 Share Posted September 15, 2025 I just upgraded to Windows 11 and the display that used to show me the count of items that I have selected in a drawing is no longer displayed. The count used to be text that would show in the bottom left of my page in Windows 10. I looked under preferences but didn't see anything that appeared to solve this issue. I am wondering what other issues I am going to have to figure out now with this update. I am using CA x12. Thanks! Link to comment Share on other sites More sharing options...
Solution DBCooper Posted September 15, 2025 Solution Share Posted September 15, 2025 Check your preferences to see if your status bar is turned on. If it is, you might try turning it off, closing the program, and then turning it back on again. If that doesn't help, you might want to try resetting your side windows in preferences. If none of those help, you might want to post a picture of your screen. 1 Link to comment Share on other sites More sharing options...
DianeP Posted September 15, 2025 Author Share Posted September 15, 2025 8 hours ago, DBCooper said: Check your preferences to see if your status bar is turned on. If it is, you might try turning it off, closing the program, and then turning it back on again. If that doesn't help, you might want to try resetting your side windows in preferences. If none of those help, you might want to post a picture of your screen. Fantastic!! Thank you for your quick response. Turning off the status bar, restarting program and turning it back on fixed it! Thank you so much! Link to comment Share on other sites More sharing options...
