signahome Posted 13 hours ago Share Posted 13 hours ago the 3d and elevations are missing the rim joist how do i fix Link to comment Share on other sites More sharing options...
DBCooper Posted 8 hours ago Share Posted 8 hours ago I don't think you actually want to see the rim joist because the siding should be dropping down to cover it. So things I would look at would be to see if your walls are set the default heights (you should not need to manually change wall heights except for special situations) or if you have done anything goofy in your floor structure. An easy way to reset your wall heights is to use the "reset to defaults" tool. If this doesn't help, then you should probably post your plan. Link to comment Share on other sites More sharing options...
Mark3D Posted 5 hours ago Share Posted 5 hours ago Check this setting Link to comment Share on other sites More sharing options...
