chrismac Posted Monday at 11:02 PM Share Posted Monday at 11:02 PM Hello, does anyone have experience with using LiDAR data alongside Chief? Such as FARO, Trimble, or Matterport. It looks like there is not a direct integration for point clouds into Chief. I have experience with this type of data in other programs, but never with Chief. Curious to know other's workflow. Any tips greatly appreciated. Chris Link to comment Share on other sites More sharing options...
Renerabbitt Posted Tuesday at 01:02 AM Share Posted Tuesday at 01:02 AM 1 hour ago, chrismac said: Hello, does anyone have experience with using LiDAR data alongside Chief? Such as FARO, Trimble, or Matterport. It looks like there is not a direct integration for point clouds into Chief. I have experience with this type of data in other programs, but never with Chief. Curious to know other's workflow. Any tips greatly appreciated. Chris Certainly. I typically order a matterpak which is an obj file conversion of the matterport scan then I slice it in blender as well as decimate it. Then import in units of meters as a symbol and save it in a plan file that youwill reference. Reference it so that you arent constantly rebuilding a heavy scene. (The scan can be a 1M poly on up) 1 Link to comment Share on other sites More sharing options...
chrismac Posted Tuesday at 09:36 PM Author Share Posted Tuesday at 09:36 PM Thank you Rabbitt! How accurate are you finding the Matterport data? I've heard it can have a large margin of error. Are there scan techniques to improve resolution? Have you used it for exteriors as well? I've heard the proprietary software for Matterport can be limiting. I have not used Matterport but am familiar with FARO in a previous role. Best, Chris Link to comment Share on other sites More sharing options...
SHCanada2 Posted yesterday at 04:00 AM Share Posted yesterday at 04:00 AM 6 hours ago, chrismac said: Have you used it for exteriors as well? I'm always looking for a good exterior scan option. But FARO seems like a pretty penny. I've tried a bunch of photogrammery apps, but none worked that well. Do you know of other options other than FARO Link to comment Share on other sites More sharing options...
Renerabbitt Posted 14 hours ago Share Posted 14 hours ago On 9/9/2025 at 2:36 PM, chrismac said: Thank you Rabbitt! How accurate are you finding the Matterport data? I've heard it can have a large margin of error. Are there scan techniques to improve resolution? Have you used it for exteriors as well? I've heard the proprietary software for Matterport can be limiting. I have not used Matterport but am familiar with FARO in a previous role. Best, Chris The pro 3 camera is very accurate since it mixes photogrammetry and a professional grade lidar sensor. Lidar from your phone will be very poor. Lidar on exterior is ok for somet things, though I personally don't see a ton of need there. I will say it only takes me 2-4 hours with a helper to measure an entire place directly into chief and take photos and do a phone lidar scan for backup. Link to comment Share on other sites More sharing options...
