chrismac Posted September 8, 2025 Share Posted September 8, 2025 Hello, does anyone have experience with using LiDAR data alongside Chief? Such as FARO, Trimble, or Matterport. It looks like there is not a direct integration for point clouds into Chief. I have experience with this type of data in other programs, but never with Chief. Curious to know other's workflow. Any tips greatly appreciated. Chris Link to comment Share on other sites More sharing options...
Renerabbitt Posted September 9, 2025 Share Posted September 9, 2025 1 hour ago, chrismac said: Hello, does anyone have experience with using LiDAR data alongside Chief? Such as FARO, Trimble, or Matterport. It looks like there is not a direct integration for point clouds into Chief. I have experience with this type of data in other programs, but never with Chief. Curious to know other's workflow. Any tips greatly appreciated. Chris Certainly. I typically order a matterpak which is an obj file conversion of the matterport scan then I slice it in blender as well as decimate it. Then import in units of meters as a symbol and save it in a plan file that youwill reference. Reference it so that you arent constantly rebuilding a heavy scene. (The scan can be a 1M poly on up) 1 Link to comment Share on other sites More sharing options...
chrismac Posted September 9, 2025 Author Share Posted September 9, 2025 Thank you Rabbitt! How accurate are you finding the Matterport data? I've heard it can have a large margin of error. Are there scan techniques to improve resolution? Have you used it for exteriors as well? I've heard the proprietary software for Matterport can be limiting. I have not used Matterport but am familiar with FARO in a previous role. Best, Chris Link to comment Share on other sites More sharing options...
SHCanada2 Posted September 10, 2025 Share Posted September 10, 2025 6 hours ago, chrismac said: Have you used it for exteriors as well? I'm always looking for a good exterior scan option. But FARO seems like a pretty penny. I've tried a bunch of photogrammery apps, but none worked that well. Do you know of other options other than FARO Link to comment Share on other sites More sharing options...
Renerabbitt Posted September 10, 2025 Share Posted September 10, 2025 On 9/9/2025 at 2:36 PM, chrismac said: Thank you Rabbitt! How accurate are you finding the Matterport data? I've heard it can have a large margin of error. Are there scan techniques to improve resolution? Have you used it for exteriors as well? I've heard the proprietary software for Matterport can be limiting. I have not used Matterport but am familiar with FARO in a previous role. Best, Chris The pro 3 camera is very accurate since it mixes photogrammetry and a professional grade lidar sensor. Lidar from your phone will be very poor. Lidar on exterior is ok for somet things, though I personally don't see a ton of need there. I will say it only takes me 2-4 hours with a helper to measure an entire place directly into chief and take photos and do a phone lidar scan for backup. Link to comment Share on other sites More sharing options...
SHCanada2 Posted September 11, 2025 Share Posted September 11, 2025 20 hours ago, Renerabbitt said: The pro 3 camera is very accurate since it mixes photogrammetry and a professional grade lidar sensor. Lidar from your phone will be very poor. Lidar on exterior is ok for somet things, though I personally don't see a ton of need there. I will say it only takes me 2-4 hours with a helper to measure an entire place directly into chief and take photos and do a phone lidar scan for backup. Lidar on the phone is only good for ~15 ft, so exteriors do not work that I have tried I do similar workflow, but I use a photogrammery app as a back up. Which lidar app is your preference? I'm currently doing elevations from photos, and attempting to measure eave heights from ground, and then discerning a heel height and peak height. It works for "simple houses" but not those with upper roof lines which are back from the front facade. Have you found any better technique? Link to comment Share on other sites More sharing options...
