PitMan71 Posted August 12, 2025 Share Posted August 12, 2025 For some reason rooms under or around stairs where the lower space is underneath the "open to below" for the stair, the ceiling height reports the ceiling height AND the floor height above.. Is there a way to force it to just report the first floor ceiling height? Thanks Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 12, 2025 Share Posted August 12, 2025 1 hour ago, PitMan71 said: For some reason rooms under or around stairs where the lower space is underneath the "open to below" for the stair, the ceiling height reports the ceiling height AND the floor height above.. Is there a way to force it to just report the first floor ceiling height? Thanks What method are you using to derive ceiling heights? Link to comment Share on other sites More sharing options...
SHCanada2 Posted August 12, 2025 Share Posted August 12, 2025 If you are not already, you need to calculate the ceiling heights using elevations. There is a topic on the forum somewhere Link to comment Share on other sites More sharing options...
PitMan71 Posted August 13, 2025 Author Share Posted August 13, 2025 2 hours ago, Renerabbitt said: What method are you using to derive ceiling heights? The finish schedule. My apologies. I thought I mentioned that. Link to comment Share on other sites More sharing options...
