sea_lyons Posted June 16, 2025 Share Posted June 16, 2025 Not sure what's happened but when I zoom in on a plan view, my line weights seem much heavier than usual. This is not just on one plan - it's all of my plans old and new. I don't think I've changed any settings and tbh I wouldn't even know where to change something like this. Any idea how to revert this? Link to comment Share on other sites More sharing options...
robdyck Posted June 16, 2025 Share Posted June 16, 2025 The first thing to check is that the view is using the correct layer set. Drawing Sheet Setup: If you have changed the Drawing Scale, this will affect the appearnace of line weights. Drawing Sheet Setup: If you have changed the Advanced Line Weight Options, this will affect the appearance of line weights. Open Help and paste 'Drawing Sheet Setup Dialog' Link to comment Share on other sites More sharing options...
sea_lyons Posted June 16, 2025 Author Share Posted June 16, 2025 2 hours ago, robdyck said: The first thing to check is that the view is using the correct layer set. Drawing Sheet Setup: If you have changed the Drawing Scale, this will affect the appearnace of line weights. Drawing Sheet Setup: If you have changed the Advanced Line Weight Options, this will affect the appearance of line weights. Open Help and paste 'Drawing Sheet Setup Dialog' Thanks Robert. I've actually never even opened this dialog box before lol. Everything was fine on Friday. Opened Chief this morning and everything looks off. These are the settings when I open a new plan - not sure if what's there is default/typical. I've fiddled with them but can't seem to get it back to where it was. Link to comment Share on other sites More sharing options...
robdyck Posted June 16, 2025 Share Posted June 16, 2025 I'd suggest opening a slightly older plan and comparing the settings to the plan in question. You could also post those files here so someone can investigate your settings to help identify the specific issue. If you don't want to post the files in the forum, you could PM me a dropbox or Google Drive link to download them and inspect. Again, best to sompare an older plan that looks correct with the plan in question. Does that make sense? Link to comment Share on other sites More sharing options...
Solution PitMan71 Posted June 16, 2025 Solution Share Posted June 16, 2025 Sounds like your Lineweights toggle is turned on. 3 Link to comment Share on other sites More sharing options...
richoffan Posted June 16, 2025 Share Posted June 16, 2025 Hi Caitlin, My apologies to you and all of your country. We are trying. There is a control to turn line weights on and off under tools as well as a toolbar icon like Shane said. There is a control for print preview under file > print and an icon as well. Both will turn them on and off while drawing. again, sincerest apologies 2 2 Link to comment Share on other sites More sharing options...
sea_lyons Posted June 17, 2025 Author Share Posted June 17, 2025 15 hours ago, PitMan71 said: Sounds like your Lineweights toggle is turned on. YES! That was it! I must have inadvertently clicked it. Thank you! 1 Link to comment Share on other sites More sharing options...
sea_lyons Posted June 17, 2025 Author Share Posted June 17, 2025 17 hours ago, robdyck said: I'd suggest opening a slightly older plan and comparing the settings to the plan in question. You could also post those files here so someone can investigate your settings to help identify the specific issue. If you don't want to post the files in the forum, you could PM me a dropbox or Google Drive link to download them and inspect. Again, best to sompare an older plan that looks correct with the plan in question. Does that make sense? Thanks Robert. It was the line weights toggle which I guess makes sense since all of my plans were affected - old and new. Link to comment Share on other sites More sharing options...
