Ringos Posted Friday at 02:24 PM Share Posted Friday at 02:24 PM Where can I control the amount of the paint blend transparency? I painted a pine board with green to make it appear like Pressure Treated Yellow Pine, which I think should be a standard color since it is used SO much. I used the blend mode. I get a blend that is a little too green and want to change the amount of color blend. 1 1 Link to comment Share on other sites More sharing options...
Chrisb222 Posted Friday at 03:18 PM Share Posted Friday at 03:18 PM 50 minutes ago, Ringos said: Where can I control the amount of the paint blend transparency? You can't currently. You can try using a different color for blending, something with less vibrancy which should work for this situation. Also, you can add your support to this Suggestion thread: 1 Link to comment Share on other sites More sharing options...
Rookie65 Posted Friday at 03:45 PM Share Posted Friday at 03:45 PM I had found an ACQ PT lumber material online and changed the material to that in my master sheet. For a decent color match to it, use the color "Meadow Grass" 1 Link to comment Share on other sites More sharing options...
Hoff_Design Posted yesterday at 05:10 AM Share Posted yesterday at 05:10 AM When I want control over the color blend of a texture, I currently export the texture and open in photoshop, adjust the color, then reimport. I added this as a suggestion to include in future versions. Link to comment Share on other sites More sharing options...
