Gawdzira Posted June 3, 2025 Share Posted June 3, 2025 This may be more of a systems issue but I also see it when just trying to access my sheet print settings. I hit the print DBX and it hangs for over 30 seconds. I know that in the evolutionary scheme of things, 30 seconds is not that long but it is a real work flow killer. It also happens when I open a pdf and hit the print function so this could be the system. My desktop where this happens is Device name MainDesktop Processor Intel(R) Core(TM) i9-10900KF CPU @ 3.70GHz 3.70 GHz Installed RAM 32.0 GB (31.9 GB usable) Device ID F417C97A-5706-4966-AF83-0AB1E5C44988 Product ID 00330-80000-00000-AA142 System type 64-bit operating system, x64-based processor Pen and touch No pen or touch input is available for this display Windows 11 pro version 24H OS Build 26100.4202 Anyone with a similar experience? This does not occur with the same CA files on my laptop. Link to comment Share on other sites More sharing options...
SHCanada2 Posted June 3, 2025 Share Posted June 3, 2025 1 hour ago, Gawdzira said: It also happens when I open a pdf and hit the print function not a CA problem then? maybe it is looking for a network printer that does not exist 1 Link to comment Share on other sites More sharing options...
Gawdzira Posted June 4, 2025 Author Share Posted June 4, 2025 Thanks, that did the trick. I deleted all the printers that were not the main critical ones that I recognized and I am back to high speed. Link to comment Share on other sites More sharing options...
