Quick Question, couldn't find anything the library
Cadwork22
Go to solution Solved by Hoff_Design,
Once you create your polyline you then select "convert polyline" and make it a 3d solid. Give it the width, depth and height dimensions you want to see. then select your material painter and apply glass to it from the library.
You can also select 'materials' and apply from there in the dialogue box.
I think I'm missing something. I converted it to a 3d solid, I went to the material tab and selected a glass type, set the thickness at .125, however to no avail.
Image is in the rendering program.
Thank you. 1956458315_Screenshot2025-05-31182724.thumb.png.4151b4cedebf474a9e1a68fec11e0a1d.png
1 hour ago, Cadwork22 said:
Theres an option for a 3d solid hole in the polyline dropdown, do you know how to access this, I was also
thinking glass walls with mullions.
Once you have created a 3D solid, you can then draw your cad polyline on it then select the 'covert polyline' icon and choose "3dhole solid" and it will punch a hole in your 3D solid.
