VeraWangCassara Posted Friday at 12:34 PM Share Posted Friday at 12:34 PM Looking for someone to help us renovating a lake house. The current structure (on the right from the picture) has an A-Frame with 3 add-ons on 3 sides. kitchen is on the right which is tiny. Another bedroom on the left. and a garage behind (you can't see from the picture) and another 1-bedroom on top of the garage. I want to open up the first floor that can connect all 3 units. that means I need to remove part of the two original A-Frame side walls. Is that something that can be done? Thanks so much Link to comment Share on other sites More sharing options...
Chrisb222 Posted Friday at 01:08 PM Share Posted Friday at 01:08 PM 30 minutes ago, VeraWangCassara said: Is that something that can be done? Yes. HOW it could be done - or whether it's even practical - is difficult to answer from what you posted, and maybe impossible to answer on a discussion forum like this. Best bet is ask a local contractor. Link to comment Share on other sites More sharing options...
Doug_N Posted Friday at 03:15 PM Share Posted Friday at 03:15 PM The answer, as indicated from Chris is yes. Before that can be done, you need to consult with someone qualified in your area to visit the building, look at the current construction, and assess what it might take, and if it would be practical. No question about if it can technically be done, but will it be worth it? Maybe is the only answer that anyone could offer from the photos. I don't agree with asking a local contractor. Ask a qualified designer, architect or structural engineer. Link to comment Share on other sites More sharing options...
CharlesVolz Posted Friday at 03:52 PM Share Posted Friday at 03:52 PM 3 hours ago, VeraWangCassara said: I want to open up the first floor that can connect all 3 units. that means I need to remove part of the two original A-Frame side walls. Is that something that can be done? Yes! That can be done. Structural supports such as columns, beams, headers, bracing, etc. will most certainly need to be designed by an engineer licensed in your state and added to the renovation scheme. Best, Charles Link to comment Share on other sites More sharing options...
