KTransue Posted yesterday at 03:12 AM Share Posted yesterday at 03:12 AM Hey folks, After evaluating X17’s new Project Management system in real-world use, I’ve pulled together a summary of how it works, where it shines, and where it’s falling short—along with a few serious risks for anyone relying on it for production work. This is a summary of a longer, more detailed critique I’ve written (with scenarios, risk cases, and proposed improvements). I’ll post that here or submit it directly to Chief if there’s interest. This isn’t a rant—it’s meant to help prevent avoidable problems and encourage practical feedback from those using the system daily. What It’s Supposed to Do: Chief now groups your plans, layouts, and assets into a single project file (.caproj) stored in your Documents folder. Chief manages the structure and linking. This is meant to: • Keep everything organized • Eliminate broken plan-layout links • Simplify project sharing and exports That’s the goal. But it’s not quite working as intended yet. What’s Not Working (and Why It Matters): 1. Layouts lose their links to plans when imported. You have to reconnect them manually every time. Risk: Incorrect or mismatched plans can get printed or submitted—potentially triggering permit rejection, construction errors, or liability for the designer. 2. Duplicate files are accepted without warning or distinction. Chief allows files with the same name to coexist in the project—even if they contain different content. Risk: Users can unknowingly work on the wrong version, or issue a file that appears correct but contains outdated or unapproved content—risking rework, confusion, or legal exposure. 3. No metadata or file history is visible. No tracking of who made changes or when. Risk: Teams have no way to verify the status or history of a file, leading to loss of accountability, inability to verify approvals, or untraceable errors in submitted documents. 4. There’s no clean way to share or extract a subset of a project—like multiple design options. You can export/import individual files, but not a bundle that retains internal structure or references. Risk: Collaborators can’t isolate just the pieces they need, and reviewers may receive extraneous or obsolete content—introducing major clarity issues and potential misinterpretation of the design intent. 5. If a team member is unavailable, their work is locked away. Project containers live in hidden folders. No export = no access. Risk: Deadlines can be missed, approvals delayed, or teams left unable to submit or revise work without access to another user’s machine—an operational and contractual risk. Why It Matters: These aren’t just workflow annoyances. If a designer delivers incorrect plans, or can’t deliver at all, the blame lands squarely on the designer—not the software. These failure points can trigger missed deadlines, rejected permits, lost revenue, or worse—career and legal consequences tied to what should have been a manageable design flow. What Would Make It Better: • Prompts on import for duplicate filenames • File tagging (draft, issued, archived) • Metadata tracking: author, modified date, version • Support grouped import/export of project subsets, like multiple design options, with links and structure intact • Persistent plan-layout linking across exports/imports • Shared-access fallback or override for unavailable team members Happy to share the full document if folks are interested. It goes deeper into each point, shows examples of where these issues crop up, and offers practical suggestions. Thanks for reading. Hope this helps someone avoid trouble. Link to comment Share on other sites More sharing options...
Renerabbitt Posted 23 hours ago Share Posted 23 hours ago Going to help you out, most of this info is incorrect....which should make you happy 5 hours ago, KTransue said: Chief now groups your plans, layouts, and assets into a single project file (.caproj) stored in your Documents folder. It is spread out around a number of different folders, and careful with the wording, this almost implies all layouts and plans get stored in a caproject file. A .caproject file only exists outside of your machine if you export one, and then and only then does it become a project file and it includes whatever plans and layouts and other documents were chose to be exported with the project as well as any assets such as material texture files. 5 hours ago, KTransue said: 1. Layouts lose their links to plans when imported. You have to reconnect them manually every time. Risk: Incorrect or mismatched plans can get printed or submitted—potentially triggering permit rejection, construction errors, or liability for the designer. This is not true if you import a layout file only and chief asks if you would like to import the associated plan files, the links will be retained. Also the links will be retained for a caproject file if they existed. If you are seeing otherwise then please report it as that shouldn't be the case and you might want to double check that before you exported a caproject file 5 hours ago, KTransue said: 2. Duplicate files are accepted without warning or distinction. Chief allows files with the same name to coexist in the project—even if they contain different content. Risk: Users can unknowingly work on the wrong version, or issue a file that appears correct but contains outdated or unapproved content—risking rework, confusion, or legal exposure. It gave me a warning if I tried to rename to the same name and it gave me a warning if I tried to drag and drop into the project with a file of the same name as another that exists in that project: Quote 3. No metadata or file history is visible. No tracking of who made changes or when. Risk: Teams have no way to verify the status or history of a file, leading to loss of accountability, inability to verify approvals, or untraceable errors in submitted documents. A team cannot work on a project file within your version of the software. It's currently not possible, so I am not sure what kind of a risk this proposes. For someone to work on a file, you would need to export it, which is very very similar to the process that it was before. Thus producing the meta data. In bried, exporting a caproject file replaces hitting save at the end of a session...and in a team workflow, the caproject file should be deleted from the project browser upon export which you can do by clicking delete, which will give you the export and delete option. 5 hours ago, KTransue said: 4. There’s no clean way to share or extract a subset of a project—like multiple design options. You can export/import individual files, but not a bundle that retains internal structure or references. Risk: Collaborators can’t isolate just the pieces they need, and reviewers may receive extraneous or obsolete content—introducing major clarity issues and potential misinterpretation of the design intent. We can do exactly this in the export project option, picking and choosing which files to export: Quote 5. If a team member is unavailable, their work is locked away. Project containers live in hidden folders. No export = no access. Risk: Deadlines can be missed, approvals delayed, or teams left unable to submit or revise work without access to another user’s machine—an operational and contractual risk This is really up to you and the team for what your standards are. If its a collaborative team, then there should be an export at the end of each drafting session. Also their is an automatic backup system as well as the archive system, both of which could be pointed to a team cloud and accessed there as well. This is really no different than it was before, since before if a team member didn't save their work or didn't have their cloud updating you'd be running into the same issue. The different is very slight. you export a caproject folder to your teams cloud..then do as you normally would. I would also suggest that if a project is being exported, it should at the same time be deleted from that machine's project manager, as now it is the obsolete version in the project browser 5 hours ago, KTransue said: File tagging (draft, issued, archived) We have this its just called folder...which is abhorrently obnoxious, since we call other things "Folders" but it works lag tags do, such as a project being tagged with multiple folders 5 hours ago, KTransue said: Metadata tracking: author, modified date, version Also have this in the time tracker or revision tool 5 hours ago, KTransue said: Support grouped import/export of project subsets, like multiple design options, with links and structure intact We have this see above 5 hours ago, KTransue said: Persistent plan-layout linking across exports/imports Double check this, it works on my end 5 hours ago, KTransue said: Shared-access fallback or override for unavailable team members automatic backup is your friend here, you can also point the archive to a shared folder so automatic archive backs up plan and layout Link to comment Share on other sites More sharing options...
DRAWZILLA Posted 16 hours ago Share Posted 16 hours ago Nice info here but as a single user, I just don't need it and will turn it off for now. 3 Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted 16 hours ago Share Posted 16 hours ago 11 minutes ago, DRAWZILLA said: Nice info here but as a single user, I just don't need it and will turn it off for now. I am also a single user and have come to really love it. I just think there is more we could do to make backing up our .caproj files. I'm hoping Chief can jump in some time to explain to me what I am suggesting does not work for xyz reasons... Link to comment Share on other sites More sharing options...
joey_martin Posted 15 hours ago Share Posted 15 hours ago 25 minutes ago, DRAWZILLA said: Nice info here but as a single user, I just don't need it and will turn it off for now. Even in my office of 10 designers we don't use it. I may play around with it when I get time, but all the exporting/importing is a no go for us. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted 15 hours ago Share Posted 15 hours ago 5 minutes ago, joey_martin said: but all the exporting/importing is a no go for us. So please go to my post above and read what I am proposing. I am addressing exactly what you would want for a team. I feel like too many Chief users accept the statuesque too quickly when a few more voices might gain some momentum. I think what I am proposing would work amazing for a team. Please check it out and share your thoughts about what you would need. Link to comment Share on other sites More sharing options...
Chrisb222 Posted 14 hours ago Share Posted 14 hours ago 1 hour ago, Steve_Nyhof said: I'm hoping Chief can jump in some time to explain to me what I am suggesting does not work for xyz reasons... Steve, the staff sometimes participates in the Q&A forum but they specifically state that they don't read all of these threads, and if you want to make a suggestion to enhance the program, to use the Suggestion forum. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted 14 hours ago Share Posted 14 hours ago Just now, Chrisb222 said: Steve, the staff sometimes participates in the Q&A forum but they specifically state that they don't read all of these threads, and if you want to make a suggestion to enhance the program, to use the Suggestion forum. Yes, I asked them to move this over to Suggestions - Thank you 1 Link to comment Share on other sites More sharing options...
KTransue Posted 11 hours ago Author Share Posted 11 hours ago 9 hours ago, Renerabbitt said: Going to help you out, most of this info is incorrect....which should make you happy So happy, Rene. Always happy for you to blow holes in my arguments ... You do it with such finesse! It appears "crow" is on the menu again ... (I keep embarrassing myself … I'm gonna have to learn to keep quiet). I've been running through your responses and there are definitely things I either missed or took a left turn on. A few of my issues, though, I’ll still defend. And, I'll keep doing what I do best ... Looking for all of the frustrating ways that'll lead a desperate man in front of a bus, and I've found enough of them that I had to start writing them all down to keep a path back to them, like bread crumbs in the forest. And, I've knocked it on its butt several times in the last two hours, just trying to find something consistent that I can pass along as fodder for continuing conversation. Too many to summarize here, though, without doing another deep dive first, but this time I have your input to lean on as well (and I really do appreciate that!). I've proven a couple of your responses true, haven't gotten to a couple, and a few I still can't get to due to brain fog and Chief programming idiosyncrasies (e.g. greyed out selections that shouldn't be greyed out, etc.). Each of them burns up some more time, and now I just want coffee or a nap, or both. However, I will concede that even without employing a true application system designer, they've still managed to get 80% of the way there, and we can probably find a way to get around that last 20%, just as we have in every other version. I just feel sorry for those that will be left confused, frustrated, and hopeless. On the other hand, it does provide more opportunities to teach, so there's that. The overarching point I was trying to make in my post wasn't the correctness of each bullet point -- there are many more -- but that the system design itself is incomplete and lacking, and the resulting PM behavior is underdressed, with holes in its genes (pun intended). The PM system's current state is born of a design that's trying to reinvent the wheel, and it's designed to rely on human behavior modification and habit more than it relies on systemization. Technically, though, I took your responses to heart, and it seems you're right … there are ways to force things to work ... if you’re curious enough to look for alternatives, resourceful enough to find them, committed enough to apply them, and rigorous enough to remember them. I know I'm probably spitting in the wind, but damn it, I want all this stuff to be as good as it can be and I just wish they'd ask for help; not just "reports" and "suggestions"! Sorry everybody ... I'll climb back down off my high horse now ... Oh, and I really don't know where this should be posted. It seems that this thread is better attended than some others, and it's more than a suggestion, and it's not a feature request, which leaves "bug report" and I don't yet have enough details written down to list all of those. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted 11 hours ago Share Posted 11 hours ago 27 minutes ago, KTransue said: I'm gonna have to learn to keep quiet Please don't! I'm sure there are many who are messing with this PM for the first time and running into a number of things just like you, and others can come along and help answer those questions. There is a number of things about the PM I really like, although I have not made a list. But I have used it now exclusively for maybe going on three weeks. There are things I want to be added which I have stated above, but so far I feel it has kept me focused within Chief as everything I am working on is right there is front of me. One of the biggest things is creating a Template Project. This way you can link the .plan and the .layout with your views and details. I start a new Project by copying the Template Project and giving it a name. The Templates in the Templates folder cannot be linked, so they to me are a bit useless. You update your Template Project with your defaults, not your templates. As least if you want to link your .plan and .layout - which I did in earlier versions in a round about way. With X17 it is more intuitive and designed to be linked. Link to comment Share on other sites More sharing options...
mtldesigns Posted 8 hours ago Share Posted 8 hours ago 7 hours ago, DRAWZILLA said: Nice info here but as a single user, I just don't need it and will turn it off for now. I'm with Perry here. I have a .plan and .layout file, all under a project folder on One Drive, files dragged and dropped to a Google Drive and Dropbox for a backup at certain stages of the project. Easy peasy.. So is this PM addition, an option where we don't have to use it? I hadn't seen much of X17 besides the vids and comments, not a beta user here. And I understand some peeps might like the PM stuff, but I'm looking for more bread and butter in these upgrades not just a different bread box to store it. That's what I am excited to see.. Did we fix stair issues, pony and railing walls issues, dimensioning options, basically most of the suggested items this past year. Honestly, I don't recall anyone suggesting a project management system, or I just missed it. My $0.05 because two pennies are more than a dime. Link to comment Share on other sites More sharing options...
Mark3D Posted 8 hours ago Share Posted 8 hours ago 11 minutes ago, mtldesigns said: I'm with Perry here. I have a .plan and .layout file, all under a project folder on One Drive, files dragged and dropped to a Google Drive and Dropbox for a backup at certain stages of the project. Easy peasy.. So is this PM addition, an option where we don't have to use it? I hadn't seen much of X17 besides the vids and comments, not a beta user here. And I understand some peeps might like the PM stuff, but I'm looking for more bread and butter in these upgrades not just a different bread box to store it. That's what I am excited to see.. Did we fix stair issues, pony and railing walls issues, dimensioning options, basically most of the suggested items this past year. Honestly, I don't recall anyone suggesting a project management system, or I just missed it. My $0.05 because two pennies are more than a dime. You can turn it off in preferences also it ask when you install if you want to use it Link to comment Share on other sites More sharing options...
mtldesigns Posted 7 hours ago Share Posted 7 hours ago 31 minutes ago, Mark3D said: You can turn it off in preferences also it ask when you install if you want to use it thx, good to know Link to comment Share on other sites More sharing options...
Renerabbitt Posted 7 hours ago Share Posted 7 hours ago 53 minutes ago, mtldesigns said: stair issues which stair issues? maybe I have answers 53 minutes ago, mtldesigns said: ailing walls issues Which? maybe I have answers 53 minutes ago, mtldesigns said: dimensioning options We did get some new ones yes Quote project management system, or I just missed it. This is one of the most requested things for the last decade..to specifically address the issue of broken links and missing files across machines and inter-office sharing It's also Chief's number 1 support call I believe...and though its not perfect..its a big step in the right direction . Also there are a ton of bread and butter things. just the 3d temp dimensions are HUGE productivity time saver. 1 Link to comment Share on other sites More sharing options...
mtldesigns Posted 7 hours ago Share Posted 7 hours ago 2 minutes ago, Renerabbitt said: issues? I really should have used the word "improvements" on stairs and railing walls instead of "issues". It def is better than it used to be. I guess I nvr had the linking issues others have since it's just me.. even though I go from desktop to laptop, being all on a cloud and only one license to move back and forth, it's always seems to work fine. "KNOCK ON WOOD" Link to comment Share on other sites More sharing options...
