Sidewalk acting as a cutout showing sky
TonyCousins
22 hours ago, TonyCousins said:
they are all acting like a hole in the grass showing the sky
House in the heavens, I hope you're charging extra for that?
anyway, like Gawdzira says, there is a layer off probably.
I always select "all layers on" in situations like this to determine the culprit.
Sometimes you inadvertently assign something to the wrong layer.  (in case you turn on Roads and you still see the sly)
