PitMan71 Posted 8 hours ago Share Posted 8 hours ago Morning all... See the attached. On the left side of this home there is a gable above which a new wall is being added. I need the exterior wall area below the roof line to be brick, while above remaining siding. I thought I could figure this out but I am not having any luck. Thanks in advance for having a look. Carmichael Remodel.plan.zip Link to comment Share on other sites More sharing options...
SHCanada2 Posted 3 hours ago Share Posted 3 hours ago if it is just for looks, fastest might be a wall material region. although that may not look that great in a black and white elevation Did you play with the Roof cuts wall setting? Link to comment Share on other sites More sharing options...
PitMan71 Posted 2 hours ago Author Share Posted 2 hours ago 27 minutes ago, SHCanada2 said: Did you play with the Roof cuts wall setting? I did... I have used this before and it worked perfectly. Only thing I haven't done is create a new drawing and see if it still does it. I didn't start this drawing so I don't know what settings are lurking about that might be contributing to this. I submitted a ticket on it too. Link to comment Share on other sites More sharing options...
PitMan71 Posted 2 hours ago Author Share Posted 2 hours ago Apparently the Abutting roof tool only works for walls on the interior of the home. Bummer. Link to comment Share on other sites More sharing options...
Solution JKEdmo Posted 2 hours ago Solution Share Posted 2 hours ago Shane, I changed the offending wall to have a brick pony wall below and then manipulated the pony wall heights in 3D elevation. Here's the result below. Give it a try. Jim Link to comment Share on other sites More sharing options...
PitMan71 Posted 1 hour ago Author Share Posted 1 hour ago 16 minutes ago, JKEdmo said: I changed the offending wall to have a brick pony wall below and then manipulated the pony wall heights in 3D elevation. Here's the result below. Give it a try. I will. Thanks. Didn't know you could edit the pony wall heights. Link to comment Share on other sites More sharing options...
PitMan71 Posted 1 hour ago Author Share Posted 1 hour ago Thanks all for the help. Shane Link to comment Share on other sites More sharing options...
