Larry_Sweeney Posted Tuesday at 01:31 PM Share Posted Tuesday at 01:31 PM Is there a way to show the upper section of a pony wall in one plan view and in another plan view show the bottom section of the same wall without the upper section changing in the first plan view? Link to comment Share on other sites More sharing options...
Solution Chrisb222 Posted Tuesday at 01:58 PM Solution Share Posted Tuesday at 01:58 PM 32 minutes ago, Larry_Sweeney said: Is there a way to show the upper section of a pony wall in one plan view and in another plan view show the bottom section of the same wall without the upper section changing in the first plan view? Yes, in the SPV Edit Active View dialog settings: The Pony Wall must be set to "Use Default": 1 Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted Tuesday at 02:10 PM Author Share Posted Tuesday at 02:10 PM Chris................Thank you for the "Head's Up" solution. Very much appreciated 1 Link to comment Share on other sites More sharing options...
