Michael_Gia Posted May 19 Share Posted May 19 Is there a quick way to get all of my exterior walls to go back to the default material for the exterior? At the moment I have to click on every wall, go to the materials tab, select the offending material, chose "library material" then select the little check box at the bottom, "use default material" This is a very common occurrence since I can go through dozens of material changes with my clients before they settle on something they like. I'm sure there is a quicker way. Also group selecting walls doesn't always allow me to change them all at once for some reason. Link to comment Share on other sites More sharing options...
DBCooper Posted May 19 Share Posted May 19 You can select "use default" with the material spray can tool and paint all of your walls at once in a camera view. 1 1 Link to comment Share on other sites More sharing options...
