Kenneth_Miller Posted May 16, 2025 Share Posted May 16, 2025 TO all, I have been using Chief for several years and am self taught so I might have missed general knowledge or shortcuts if attending conferences. To that end, I find the railing tool to be hard to configure correctly. The outer edge of the finished beam should line up with the edge of the finished column below, which should line up with the outer edge of the foundation block or pier below. (Some exceptions are possible). When I align the foundation below a railing above it appears to centerline under the railing. I usiall add a 3-d poly line aroudn the perimeter of the porch and offset it +4" to get it aligned properly then add a porch deck overhang 7" or so just to make it look correct Also the "rail to beam" doesn't size the beam to the width of the column. Any help or thoughts would be appreciated. Link to comment Share on other sites More sharing options...
Mark3D Posted May 17, 2025 Share Posted May 17, 2025 Watch this video Railing Walls - Video | Chief Architect asuming your are still not using x8 if you are in x16 update your signature in the forum Link to comment Share on other sites More sharing options...
Chrisb222 Posted May 17, 2025 Share Posted May 17, 2025 15 hours ago, Kenneth_Miller said: I find the railing tool to be hard to configure correctly. Same! Study this Suggestion thread for an in-depth analysis of pretty much all issues involving your question. It will help you tremendously: 1 Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted May 18, 2025 Share Posted May 18, 2025 On 5/16/2025 at 6:19 PM, Kenneth_Miller said: TO all, I have been using Chief for several years and am self taught so I might have missed general knowledge or shortcuts if attending conferences. To that end, I find the railing tool to be hard to configure correctly. The outer edge of the finished beam should line up with the edge of the finished column below, which should line up with the outer edge of the foundation block or pier below. (Some exceptions are possible). When I align the foundation below a railing above it appears to centerline under the railing. I usiall add a 3-d poly line aroudn the perimeter of the porch and offset it +4" to get it aligned properly then add a porch deck overhang 7" or so just to make it look correct Also the "rail to beam" doesn't size the beam to the width of the column. Any help or thoughts would be appreciated. Make sure to give it a +1 so Chief knows more and more people want to see something updated. Thank you Link to comment Share on other sites More sharing options...
