StephenM Posted Monday at 07:06 PM Share Posted Monday at 07:06 PM Having a brain fart here and can't remember how to change the depth of the ceiling? Currently my ceiling cuts about halfway through my trusses, but I need the ceiling to be lowered so it sit under the trusses. Can attach a zip file if needed. TIA for any help! Link to comment Share on other sites More sharing options...
Michael_Gia Posted Monday at 08:18 PM Share Posted Monday at 08:18 PM 1 hour ago, StephenM said: I need the ceiling to be lowered In the Structure tab of the room dialogue box, "Relative Ceiling Height" Link to comment Share on other sites More sharing options...
StephenM Posted Wednesday at 10:18 PM Author Share Posted Wednesday at 10:18 PM On 4/28/2025 at 2:18 PM, Michael_Gia said: In the Structure tab of the room dialogue box, "Relative Ceiling Height" Tried playing around with this dialogue box, but haven't had any luck. What am I specifically looking to adjust in there? I've also attached the plans if that helps. Project 2.plan.zip Link to comment Share on other sites More sharing options...
ericepv Posted 20 hours ago Share Posted 20 hours ago Select the roof plane and open the DBX, go to the 'Structure' tab. In the 'Roof Layers' section, you an edit the framing. Is this what you're looking for? Link to comment Share on other sites More sharing options...
StephenM Posted 9 hours ago Author Share Posted 9 hours ago 10 hours ago, ericepv said: Select the roof plane and open the DBX, go to the 'Structure' tab. In the 'Roof Layers' section, you an edit the framing. Is this what you're looking for? So I did that, but it didn't adjust my roof plane to meet the same depth of my trusses. Do I have to regenerate the roof planes after adjust the framing thickness? Link to comment Share on other sites More sharing options...
ericepv Posted 5 hours ago Share Posted 5 hours ago Yed, unless you have Auto Rebuild Roof turned on. Link to comment Share on other sites More sharing options...
