How to change the ceiling depth?
StephenM
Having a brain fart here and can't remember how to change the depth of the ceiling?
Currently my ceiling cuts about halfway through my trusses, but I need the ceiling to be lowered so it sit under the trusses. Can attach a zip file if needed.
TIA for any help!
On 4/28/2025 at 2:18 PM, Michael_Gia said:
In the Structure tab of the room dialogue box, "Relative Ceiling Height"
Tried playing around with this dialogue box, but haven't had any luck. What am I specifically looking to adjust in there?
I've also attached the plans if that helps.
Project 2.plan.zip
10 hours ago, ericepv said:
Select the roof plane and open the DBX, go to the 'Structure' tab. In the 'Roof Layers' section, you an edit the framing. Is this what you're looking for?
So I did that, but it didn't adjust my roof plane to meet the same depth of my trusses. Do I have to regenerate the roof planes after adjust the framing thickness?
